Avenga's 5 speed conversion project.
Started by avenga, February 08, 2011, 11:44:56 AM
oldschool
Okay if you don't mind the gear lever close to the hand brake!
The Sierra shifter sits 75mm further back than the Avenger one.
avenga
Yeah I am pretty sure it would come up under the handbrake or stupidly close to it.
Move the shifter is the best way because then it all looks nice and stock. If you look at my photos you can't even tell from inside, I even used the same gearknob and the shift pattern is the same, just with a new 5th gear.
I know this is the "wrong" thread to update
BUT someone showed me this UK Belhousing option, at current Conversion Rate = NZ$660
https://motorsport-tools.com/catalog/product/view/_ignore_category/1/id/80297/s/talbot-sunbeam-avenger-1-6-to-for-ford-type-9-rocket-alloy-bellhousing/
may be an option for some in the future
