Avenger Related => Technical => Topic started by: Bricstar on August 28, 2015, 07:06:44 PM
Title: Oil for gearbox
Post by: Bricstar on August 28, 2015, 07:06:44 PM
Hey  wanting to fill up my gearbox with new oil but I'm unsure of what to use? Is it the same 15w I put in my engine or something different. Pleas help!! :)
Title: Re: Oil for gearbox
Post by: oldschool on August 29, 2015, 11:13:37 AM
Just use engine oil...SF to SJ spec. Can't use newer spec oils in Avenger engines and gearboxes as they're made for modern cars.
Post by: Bricstar on August 29, 2015, 07:33:20 PM
I think I run my 1500 on 15w40... Is that alright to use? I looked it up and it says it boils take about 1.7 litres of the stuff :/
Post by: oldschool on August 29, 2015, 09:18:15 PM
Sounds fine!
Post by: Scarlet on August 31, 2015, 01:01:21 AM
Hi Ross, is the reason for not being able to use modern oil something to do with the modern oil attacks the brass syncro rings, or is it because it is to thin?
Post by: oldschool on August 31, 2015, 02:16:37 PM
Not too thin Steve, it's because modern oil is more slippery and the synchros might not work so well. They also removed some of the additives which benefitted older engines.
Post by: JoKer on August 31, 2015, 04:46:23 PM
I've never put oil in gearbox but would assume gear oil better than engine oil?
plus I love the smell of Diff oil, you just cant wash it off your hands
Post by: Bricstar on August 31, 2015, 07:08:03 PM
cool well thanks for that one, i have recently had a lot of problems with my brakes too. and it looks quite costly getting the master cilynder and brake booster reconditioned so i wanted to ask if you boys knew (or happened to have any spares...?)
thanks in advance
