Avenger Related => Technical => Topic started by: Fish on March 02, 2012, 09:33:05 PM
Title: Starter motor trouble
Post by: Fish on March 02, 2012, 09:33:05 PM
Turns out my starter is packing a sad but as the casing is rusting (Surface thankfully) Its a Lucas M35J-PE, do you reckon its worth refurbishing?
Title: Re: Starter motor trouble
Post by: oldschool on March 02, 2012, 10:50:59 PM
Yes they're pretty easy to take apart, the brushes come off the end of the starter. Most probably just needs a good clean and lube to work ok again.
Post by: Fish on March 09, 2012, 05:50:04 PM
Yeah, its nearing/at the end of its life, how much is reasonable for a replacement (Also best Avenger starter)
Post by: oldschool on March 09, 2012, 06:02:48 PM
That is the best Avenger starter, as it's the pre-engaged type with a solenoid. They're normally $50 from the wreckers.
The Avenger uses a similar starter to the 1800cc BMC B series engines used in the Morris Marina and MGB.
If using a non-Hillman one, make sure the solenoid is offset towards the top, needed to clear the steering universal.
Here's an expanded picture of your starter...handy if you're going to take it apart....
http://www.collection.archivist.info/showresult.php?prog=1&srcprog=searchv13.php&srcdata=title&Type=PS&Accn_no=2921&subject=8058
Post by: blekkja on March 09, 2012, 06:56:44 PM
If you get a Morris one you will need to swap the mounts. I brought one NOS and it didn't fit - it was cheap and easy to swap the attaching point over though.
Post by: Nikolai on March 09, 2012, 08:26:44 PM
I am selling my Hillman Avenger 1500 Single Carb Engine (Comes with Twin Carbs and Twin Carb Manifold!)
You would be able to grab the starter from that if you like - never had a single problem with it.
Located in AKL.
Post by: Fish on March 10, 2012, 11:52:48 PM
Well I've already got a set of Twin strombies and manifold beside me and I'll have a nosey around more locally if you don't mind Nikolai. Thanks Oldschool, but I've already had it apart 3 or so times, working from the Haynes manual.
Post by: Fish on March 12, 2012, 08:11:06 PM
I've got hold of a Lucas M35J (inertia started) That goes with the rear facing chamfer on the flywheel right?
Post by: oldschool on March 12, 2012, 09:21:10 PM
Yes that's right, but if you were using the M35J-PE it needs the chamfer on the front, or is that why it's munted...starter motor doesn't match the ring gear chamfer?!
I think all factory original 1300/1600 motors used the PE (pre-engaged) starter while only the early 1500 used the inertia type.
Post by: Fish on March 12, 2012, 09:47:27 PM
It engaged fine, it just wouldn't turn and still won't after being stripped and cleaned. It spun once, I double-checked and it shorted.
Post by: oldschool on March 12, 2012, 11:01:17 PM
Sounds like a stuffed armature then, I think Nikolai has a PE starter available, part of the Hillman bits he's selling from his Nissan motor upgrade.
Post by: Nikolai on March 12, 2012, 11:29:45 PM
I think Fish is a little far away :p (UK)
I'd suggest trying Speedy Spares:
http://www.speedyspares.co.uk/ROOTES/AVENGER/avenger%20report.html
Post by: Nikolai on March 12, 2012, 11:31:05 PM
SS110   Inertia Type Starter Motor Exchange   Deposit ?20   ?70.00
DRS293   Pre Engaged Starter Motor Exchange   Deposit ?20   ?47.00
http://www.speedyspares.co.uk/ROOTES/AVENGER/avenger%20reportPage5.html
Post by: Fish on March 13, 2012, 09:22:04 PM
Cheers Nikolai, but I'm in Christchurch, Canterbury.
Post by: oldschool on March 14, 2012, 10:13:05 AM
There's a PE Avenger starter on TradeMe for $25, just put your solenoid on it.
