With the Avenger 4x108mm stud pattern will 4x110mm wheels fit.
i had some modgies that fit a 4x110 stud pattern, that were actually 4x108, so, maybe
they will fit if you file the holes out but thats dodgey as fuck. Avengers PCD is 4x108 so only 4x108 PCD rims will fit lol.
I ordered my wheels today, if it helps. From Elite Wheels.
$2000 incl Toyo Proxes (great tyres), shipping, powder-coating and four brand new rims with some pain in the ass dimensions.
Same ones as Richard is getting. D Windows.
What size are they?
15x7 with 205/50/r15 fronts and 15x8 with 225/50/r15 rear.
My wheels finally shipped from Daimond Racing Wheels yesterday.
Pics??
Mine is in a truck somewhere between Illinois and LA.
They are set to reach my mates warehouse in Compton, LA on Friday, then it is Straight outta compton via a boat to NZ so I will have pics in about 5 weeks time :P
Nikolai's are still being made so and his doesn't arrive up in Auckland until the 23rd of feb. So they are also hard to take pics of.
But here is an example of what they will look like.
Mine are gloss black spun steel racing wheels (16lb each) and Nikolai's are heavier DOT rated road wheels (26lb each) and his are matt black.
(http://www.jdjeepstore.com/images/P/15500.01.jpg)
And here is a picture of the rubber I am buying Toyo Proxes T1R
(http://www.hyper.co.nz/images/products/large/toyo_prx_t1r_L.jpg)
Nikolai is using a slightly different Toyo tyre. Toyo Proxes 4
(http://www.hyper.co.nz/images/products/large/toyo_proxes_4_L.jpg)
Yup thanks for that Richard.
Please note guys, that size rim will NOT fit properly without flares/guard chop AFAIK.
The Proxes4 are meant to be a more durable compound and last longer with pretty much the same performance as T1Rs (which are apparently being phased out over time although heaps of stock still around).
I love those rims. I had toyo proxes on my Avenger, they made it handle soooo good. Like it was on rails infact.
Im interested to see what they look like on the cars with and without flares.
seemed like the best place to post these I stumbled across
https://www.wheelvintiques.com/15x10-smoothie-primer-4x4-25-4x4-5-bolt-4-5-backspace.html (https://www.wheelvintiques.com/15x10-smoothie-primer-4x4-25-4x4-5-bolt-4-5-backspace.html)
15"x10" lol $80 US each
Nice. It will be pretty hard fitting 15x10 on an Avenger. My Avenger Panther has 15x8 and that has pretty big flares
