Avenger Related => FAQ and Help => Topic started by: avenga on January 18, 2011, 02:18:16 PM
Title: How to post a message on the forum
Post by: avenga on January 18, 2011, 02:18:16 PM
Here is some steps on how to post messages to the forum. A full guide can be found in the help link (http://www.avenger.co.nz/forum/index.php?action=help) under the Posting section (http://www.avenger.co.nz/forum/index.php?action=help;page=post)
Starting a New Topic
Browse to the board where you wish to post and click the New Topic button (positioned by default at both the top and the bottom of the board, as shown in the User Help Introduction (http://www.avenger.co.nz/forum/index.php?action=help;page=index#message)), which should take you to the Start new topic screen. While this presents a number of options, the two most important are the Subject field and main Message field (not labeled as such, but obvious by its size). So enter your subject and start to type (or paste) your message into the main text area, noting that a message missing either a subject or a body will not be accepted for posting until it has both. If you're happy with your plain text message, you can then post it by clicking the Post button and/or preview it first by clicking the Preview button, but there are many further options (http://www.avenger.co.nz/forum/index.php?action=help;page=post#standard) available to make things that little bit more interesting.
Replying to a Topic or Poll
Replying to a topic or poll is basically the same as starting a new topic, but it's not necessary to enter anything in the Subject field unless you wish to change what's already there. To vote in a poll, you simply have to select your chosen option(s) and click Submit Vote.
'Quick Reply' has been enabled, a simple reply field will also appear after the post(s) on a page, but you'll have to type your Bulletin Board Code and Smileys manually if you choose to use it.
Quoting a Post
To reply to a post by quoting it, you can either click the Quote button for the relevant post and add your own message to the quoted text or click the Reply button followed by Insert Quote from the relevant post in the 'Topic Summary' below, but note that:
Both these options add a link to the original post showing the name of the poster and the date and time of the post, whereas the Bulletin Board Code quote tag simply quotes the relevant post without this additional information.
You can also retain or add the 'author' attribute independently of the full Quote function, as demonstrated in the SMF Bulletin Board Code Reference below.
Modifying or Deleting a Post
To modify a post, click the Modify button and make your changes. Note that most forums are likely to be configured to show the date and time of the last edit, but the administrator(s) may also allow a short period to elapse before this happens.
To delete a post, click the Delete button followed by OK from the Remove this message? box that appears. Some forums may also allow you to remove topics or polls that you start, but the buttons for these are usually at the bottom of the page.
Any other questions please consult the Help page (http://www.avenger.co.nz/forum/index.php?action=help) Or PM me (http://www.avenger.co.nz/forum/index.php?action=pm;sa=send;u=1) and I will be able to help you
