Avenger Related => Technical => Topic started by: Doozer on April 01, 2026, 07:57:45 PM
Title: Bearing tolerance/ clearance
Post by: Doozer on April 01, 2026, 07:57:45 PM
Good evening all, does anyone happen to know what the bearing clearance/ tolerance for the crank is for a 1600?
Any help appreciated.
Errol.
Title: Re: Bearing tolerance/ clearance
Post by: JoKer on April 02, 2026, 12:31:22 PM
My (early) Workshop Manual says :
Quote1300 Single Carburettor 1300 Twin Carburettor 1600 Single Carburettor 1600 Twin Carburettor
Crankshaft
Main bearing running clearances
0008-0028in. (0,020-0,21mm) 0008-0028in. (0,020-0,21mm) As 1300 As 1300
Connecting Rod
Big end side clearance
007.019in. (0,178 0,483mm) 007.019in. (0,1780,483mm) As 1300 As 1300
eg 1600 'same' as the 1300cc clearances
(https://i.imgur.com/W2WpdIE.jpeg)
Post by: Doozer on April 02, 2026, 02:31:55 PM
Cheers Jared, that's a handy version of the workshop manual you've got. I'll be in touch if I need any other measurements.
Cheers
Post by: JoKer on April 09, 2026, 11:05:44 AM
I just hope it's accurate info & yeah one of the things I managed to rescue from Ron's collection a few years ago
