Avenger Related => For Sale or Wanted => Topic started by: vitamin c avenger on May 25, 2021, 09:43:42 PM
Title: Automatic Transmission
Post by: vitamin c avenger on May 25, 2021, 09:43:42 PM
Hi would anybody have an auto transmission mount and cross member they would  want to sell or even a picture of what one looks like. Cheers
Title: Re: Automatic Transmission
Post by: JoKer on May 25, 2021, 11:11:26 PM
I can get a pic, but none for sale though sorry
have been offered a BW65 (never heard of them before)
Avengers came with BW35 : 3 speed early pre 76
and BW45 speed
and yes different bolt pattern / mount to Marina and Triumph BW35/45 (I've tried and tested the options when I was looking
give Irish Dave a buzz he 'might' know of some in the area OR might be time to go manual? (agree much smpler to stay auto if you can)
Post by: avengertiger on May 30, 2021, 06:40:14 PM
lol its what i used to bolt in my 5 speed conversion all i had to do was slot one hole and the whole assembly worked like a dream.
it was the only one i had.
Post by: vitamin c avenger on June 01, 2021, 06:54:00 PM
Hey, did you use a ford sierra spigot bearing?
Post by: JoKer on June 01, 2021, 08:24:12 PM
(i'vr only got e dribs and drabs of info posted on this forum ove the past 10 years)
Quote from: oldschool on August 20, 2016, 05:48:00 PM
You use an Avenger clutch, release bearing, fork and cable...will need to make a gearbox spacer, fit a pivot, cut a slot for the fork and make a cable retainer if you're using an auto bell housing.
source : http://www.avenger.co.nz/forum/index.php?topic=926.0 (http://www.avenger.co.nz/forum/index.php?topic=926.0)
another :
Quote from: hunted on January 21, 2011, 10:14:37 AM
Cool article I found on how to put a seierra 5 speed into an avenger. doesnt look too hard if you have the skills and tools
http://rootesgroup.proboards.com/index.cgi?board=general&action=display&thread=140 (http://rootesgroup.proboards.com/index.cgi?board=general&action=display&thread=140)
and "Avenga's 5 speed conversion project."
link : http://www.avenger.co.nz/forum/index.php?topic=60.msg1345#msg1345 (http://www.avenger.co.nz/forum/index.php?topic=60.msg1345#msg1345)
(hope some / any of that was some help? might do this one day myself)
Post by: avengertiger on June 01, 2021, 08:50:28 PM
Quote from: vitamin c avenger on June 01, 2021, 06:54:00 PM
no used a bronze bush which is a bit harder on the gearbox vibration wise,but its a rally car.there used to be a bush available years ago with the right ID/OD for the avenger crank and sierra input shaft.From memory i thought it was a vauxhall carlton which was never sold here,so something holden might work you would need a catalouge or something to search through with the sizes on it.
i think the sierra one is a little small to fit into avenger crank or big cant remember which.
