Author Topic: Jokers evolving Rally Avenger  (Read 17451 times)
Offline JoKer
  • Hillman/s since '97
« on: January 14, 2011, 07:23:51 PM »
Pre History on this car via https://www.facebook.com/groups/793190637378550/
Quote from: NZ Rallying History facebook page Trevor Weir
Built by Miles Fowler in Wellington, updated from standard GL body shell to Series 7 Chrysler just before I bought it in the mid 1980's. Used in many club level events then sold to Andrew Elder in the Hawkes Bay. Rolled at Salisbury Rd hillclimb and reshelled into a GLS shell. Andrew sold it back to Peter Weir as his first rally car. This has done soooooo many events and is a bit like Grandad's axe !!
Please Discuss here : Jokers evolving 1978 Avenger Discussion
Start way back when I was 17 in '97
bought it off a 'mate' for $1k standard 1300
poo brown with Black vinyl roof
Hunt for more powah = 1600
then TC
last WOF/rego 98/99'ish
couple of radiators
blew 2x spider gears thrashin tits off it - sick of that = welded up for fun
Rolled in an Auto-X 2007
https://www.instagram.com/p/BB8uUxbSo8X/?taken-by=akiwijoker
Walk around vid :
Salvaging EVERYTHING but bare shell pics :
last flight vid :
(nearly cried NEARLY!)
re-birthed ex T-weir shell with cage (he has more history of it that I have forgot)
Pics assembling :
Ruanui Rd 1st outing - Bent drivers side front :
Otaria Road in car Vid :
Pics - bent Pasengers side front :
R
tried some Italian Solexes which gave grief
s***ty running vid :
return to Strombergs = 35kw yeti's Dyno 2010
vid :
Pics :
custom made CNC ACM panel adapters to fit Ramflo's I bought for the solex's (to be reinstalled when I have time/money to pay for a tune)
SKIDS :
EDIT : (pix and vid's as I find them on my pc's)
Discussion : I'm happy for discussion in this thread :p
My wood/work shop
Spares down at Wilf's
have since found at least 2 more to scrounge from
edit : too lazy to re-word/write
Offline JoKer
Re: Jokers evolving 1978 Avenger
« Reply #1 on: February 08, 2011, 09:12:41 PM »
Otaria Road Dec 2010
Offline JoKer
« Reply #2 on: March 21, 2011, 08:19:17 AM »
sooo managed to complete Whariti Hillclimb weekend 12/13 mar
never completed a run Sat - not even the Recce - ALWAYS CHECK YOUR NUTS
wobble wobble nice newly slotted rim grrr
1st run oops
2nd run Co-driver "Jared there's smoke"
Basically we turned around and ran 1st with very little time to cool down - water temp off the gauge after 1km loose rad pressure - fuel line next to 'zaust melts a hole and sprays flammable stuff towards firewall/ignites oil breather and lines on top of the motor - nothing substantial lost except my COOL Talbot sticker :/
drove it back down :P
/end Sat (Skip 3rd final run for the day)
Sun - car relictant to start - I give up, mates roll it off and tow- start it
suffer major heating issues all day again BUT complete all 5 runs with improvements on every one!
8:30
8:09
8:06.50
8:06.05
7:59!!!!
40th over all last in class BUT I DONT CARE ahaha
cheers to Andrew via Duncan have sorted a worked motor and soem extra spares and 13x6 for the fronts and 13x8's for the back
Will be blazing around Taupo on the 15th April after a quick trip to dyno just to see exactly what increase a small wad of cash can get :P
pic dump - editing/ordering now
slightly over filled with oil - did not smoke till it was left idleing for over 5 mins (would not start hot - assume rings/lost of compression on 1 or more cylinders
ie the motor is relatively poked and not surprising for a 30+ year old donk!
so trip to welly over weekend :
Smart wee collection ex-Street stock?
balanced everything supposedly capable of 10k rpm
EOI thread  for more info http://www.avenger.co.nz/forum/index.php?topic=76.0;topicseen
wag is on bump-stops and flattened Exhaust just exiting his driveway haha - worth it!
Offline JoKer
« Reply #3 on: March 23, 2011, 02:03:36 PM »
EEk crank Grind (did not matter if it was the Balanced original or the OEM spare I sent up :
Grind $270
Main Bearings .020 $140
Big ends 0.40 $80
Thrusts (cant read writing on quote) std $52
Freight $12
Total $554 inc
do it once do it right!
will have back on Tues next week
Offline JoKer
« Reply #4 on: March 30, 2011, 08:43:30 PM »
Wheels are now Black
Old motor on the floor
new motor still on the stand, crank back, NOS BEB shells, just waiting for oil seals :/
water blasted Bay/bonnet
pics when done - I have some progress shots on ph
Offline JoKer
« Reply #5 on: April 03, 2011, 07:36:38 PM »
ok
so turns out there was a teaspoon of water/moisture sitting on the valves and a fair amount of rust, nothing a bit of valve paste/elbow grease cant rectify
head off, cleaned the whole block
pistons out, concerned about the amount of slap
not blaming anyone, just sorting it out :P
pics after 'puter restart, also was some weird dust on the pistons which inspired to remove/check head glad i did now , flowed out on rotation of stand
there was mention of maybe should not run 'hot' plugs on av-gas.. fair amount of pitting - suspect Det
Offline JoKer
« Reply #6 on: April 03, 2011, 09:58:52 PM »
all of these are Thumbs - click to view larger
     there was this really big rock
saddesst part loosing this sticker       my solution to Mounts
this material was coming out ports decided to remove heads         glad I did!
          piston look alloy clean as a whistle! this is how you do it          ID marks        Better!
Offline JoKer
« Reply #7 on: April 13, 2011, 01:58:10 PM »
clutch aligned at lunchtime - figure better check spigot and its STUFFED fingers crossed for same day courier from Palmy and another $40 i dont have....
drop in and turn over tonight wit the hand of some GC's
Offline JoKer
« Reply #8 on: April 17, 2011, 10:51:27 PM »
http://s1081.photobucket.com/albums/j356/kwikaus/?action=view&current=PICT0243.mp4
Offline JoKer
« Reply #9 on: April 18, 2011, 08:55:17 AM »
Yellow Line is the oem 30+ year old tired 1600
BLUE LINE IS YEEEEEEEEEEEEAAAAAAAAAAAAAAAAA
Offline JoKer
« Reply #10 on: April 27, 2011, 08:38:07 AM »
I love it when the Courier calls in with TREASURE!
Cheers avenga/Richard!
Offline JoKer
« Reply #11 on: April 27, 2011, 11:48:59 AM »
Tour lap (ie hence no helmets/passengers)
Offline JoKer
« Reply #12 on: May 02, 2011, 12:26:59 PM »
okay : just had quote to weld the alloy on the intake $100 OR I could just fab un a wee bracket to bridge it and hold things tight.....
I would like to to look nice :/
Offline JoKer
« Reply #13 on: May 03, 2011, 09:58:29 PM »
its running
on the Dellortro's :D
pics/vid soon - just missing the wee nut still on plunger but its all there ......
think I just ran out of gas!
Offline JoKer
« Reply #14 on: May 03, 2011, 11:43:32 PM »
first run tonight :P
idle about 2k low revs till I hop in car... up to about 7k
dyno FRIDAY!
have i Mentioned i do things last minute sometimes?
may have to pickup on sat morn on way to Auto-X Thi HQ
cars
cars
